Race Gas in E55, ECU adaption time? Going to race tomorrow, Racers come on in!
Been awhile since I ran my car at the track. I can't remember when I added race gas into my car to let the ECU adapt.
Been awhile since I raced my car or any for that matter. Besides showing a R8 V10 what time it is from 60-130 ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
I picked up some MS109 nearby and wondering if you should run straight no mixing. As its says its a solid replacement for pump gas street vehicles running low to moderate boost.
Or should I mix it 50 -50 with pump gas. Im pretty sure I poured it straight into my car and ran it last time. Any thoughts or advice appreciated I'm going to the track tomorrow night!
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![tyson](https://mbworld.org/forums/images/smilies/boxing.gif)
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
I disagree, but that's me.
Your gonna loose power running it MS109 straight without tune. I lost power running Q16 on m 93oct tune. But I have never run MS109, so what do I know?
Q16 is a very heavy racing fuel. It would richen your motor for no reason. I can see why it didnt work.
I thought Cali had lower oct than us with no emissions. We still have 100oct on pump.
Good Luck!
if you dont have star, get the gas tank as low as possible, fill with 2 gal of pump and 2 gal of ms109, drive the car hard let it adapt. then go back and put the rest of the MS109 in the tank.
If you have star do what Craig said.
1 Post
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
You wouldn't see the true benefit of running a higher octane fuel without tuning for it IMO.
If i was going to run it though, i would run the tank as low as possible and then put in whatever fuel i wanted. Good luck.
But, there is a big BUT... Im talking about using specially formulated unleaded race gas, Meant to be a substitute or enhancement for pump gas on high compression cars and med boost street cars. If you do what RB JUNKY did before for example is worst case scenario.. Sorry RB no disrespect. :-P
Heavy leaded race gas meant for high boost tuned vehicles will richen your car up too much and actually slow it down substantially. I tried the same thing as RB Junky many years ago and lost a race because of it. Lesson learned.
The MS109 is a great fuel but, it cost's a lot!! Ouch!! Might be time for some methanol.
Sweet, thanks guys. Ive ran it before on all my cars and it does pickup power. NA, if you have high compression,boosted for sure. You never know how good the fuel is in your car. So bumping the octane helps add power.
E55, CTS-V Wagon, Duc 1098R
Whether it's leaded or not doesn't MS109 have a lower stoich point, I think mid 13's right whereas regular pump gas is 14.7? I would think you should have the tune set for this to gain power and be safe, a normal tune would have you lean I believe although I am no expert![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
I mix 50-50 with pump gas, runs awesome!
