ran out of gas - CEL now on
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
so I did some searching and it appears my fuel sender might be bad, at least I think that is the side. I ran out of gas and someone came and we put a gallon in. Car started, drove to the nearest gas station and filled it up completely and it only took 9 gallons....So I need to figure out which side I need to replace. Now my CEL is on (I may run to get that code) and my fuel gauge doesn't work.
And on a side not my fuel gauge is way off as well...
Is there a smell? Leak? I thought those with the fuel sending problems can usually tell from where the smell is coming from and/or there's a leak/puddle build up of fuel. I could be wrong...maybe folks with this problem can chime in.
