Quick camshaft install question!
Are they not setting due to lifter to valve spring contact in which the valve springs need to be compressed by the proper torque sequence of the camshaft bridge?
I need help before I start drinking......
Now, my problem is that the driver side camshaft sprocket key does not line up with the camshaft notch. Then again, why in the hell am I asking you guys? Who here @MBworld installed their own camshafts.
So yoiu can take the MBs own Workshop manual as a reference :-)
Maybe that was the order of the install? I shall remove both rocker arm bridges and re-install in that order. (I did not use that order the first time) I will report back later tonight with the results.....
Let's say, hypothetically speaking, after cutting the zip ties to release the tension on the sprocket (not the zip ties on the sprockets to hold chain against the teeth) the timing chain had enough slack to skip a tooth. How would I know? The sprocket key is not lining up by half the width of the key?
I honestly can't recall what I did to get everything lined up but bottom line, once I had everything in place...blame he beer, but I went ahead and did the buttload of crank rotations (14-17ish?) once I had everything snugged up to make sure all of the timing links were in the right places. Best of luck, when it's done it'll all be worth it!
Second off, the reinstall rocker arm bridge with left sprocket to right sprocket install worked. She's done. No issues. Everything fell into place.
thanks.
