how to drain gas tank
Old Sep 26, 2013 | 06:49 PM
sircl55amg's Avatar
2006 cls 55 amg
hi guys, im going to the track this weekend and i need to drain out the gas...
what is the best way to do it ?
thanks
Old Sep 26, 2013 | 07:27 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
thanks
120MPH for 30 min should do it!
Old Sep 26, 2013 | 07:46 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
If you have star, you can remove the braided line to the fuel rail on the fire wall side, connect a hose to it, and "activate pumps" in Star. That's how I did it. The fitting for the hard line is a metric fitting but I can't remember the thread size. I'm pretty sure you can get a hose around the hard line with a clamp and call it good...
Old Sep 27, 2013 | 06:31 AM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
The easiest way to drain the tank is:
Connect a fuel pressure gauge fitting to the port on the fuel rail.
Connect a long enough hose to this line to reach the receptacle you are going to fill.
Start the engine.
If you are going to be filling multiple containers. You can clamp the line with pliers. This will allow you to swap containers without spillage.
The engine will run without any concerns. Draining the tank in this method allows the siphon jet system to work properly. Draining both sides of the tank.
Old Sep 27, 2013 | 06:54 AM
sircl55amg's Avatar
2006 cls 55 amg
great !!!! i will use the port
thank you !!!!
Old Sep 27, 2013 | 05:58 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Nah - - - that won't do it. I get about 18 MPG cruising at 120 MPH
