SRS Wire
New 05 E55 AMG owner here. Just purchased and the sea warning light is on and the seatbelt shows as off. The problem has turned off and back on a couple times which leads me to believe its a loose connection.
I unbolted the seat and turned it over to see if I could see a loose wire but nothing.
I've attached some pictures to see if someone can point out which wire goes to the SRS sensor so I can look more closely at that one specifically.
I've searched but only found some pictures on a w210 write-up that doesn't look the same as my seat.
Thanks!
https://www.dropbox.com/sh/tb3jwh3ivgjol48/SPEHtqb8yG
I thought it was the red, white, and brown plug on the left side rail but realized there are actually (4) red, white, and brown plugs on that group of plugs and they all go to 4 separate pump type things. That made me believe its not on that left rail. Other than that I have no clue.
Also, when I purchased, the code was read and was confirmed as the SRS sensor inside the passenger seat. I believe it to be a loose or frayed wire as the error goes on and off intermittently. That is why if I knew which wire it was I could at least verify it's not something simple before forking out the cash to read a code again or worse have the dealership fix.
Also, I'll likely purchase an emulator if it is in fact the sensor so knowing the wire is necessary for this.
The listing states this is the case, however, there is another listing that has different model numbers that also state it is for an E55 AMG.
I still haven't found the correct wire, however, I plan to remove the seat completely and see if anything stands out to me. I ordered sensor cleaner that I will spray on every plug, after unclipping, while the seat is out. If that doesn't work then I will be ordering the sensor.
FYI, those yellow plugs are SRS related.
