! NEW ! - Comprehensive Upper/Lower Pulley Boost Matrix...
Old Feb 28, 2016 | 01:36 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
So 74mm SC Pulley is what?
Anyone took the difference in Superchargers into account. The newer Partnumbers with "580" in the end produce more boost from factory.
Old Feb 28, 2016 | 01:45 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
None of the charts have a 74 sc pulley. Mathematics would put it in the range of a 185 crank pulley. You would want/need bigger injectors and better cooling. 77/180 is as big as you should go on stock injectors and aftermarket h/e and small reservoir. Even then you can't do back to back runs without heatsoak. Trunk tank,meth or KIller chiller and you would be better off.
Also some member have added another H/E Infront of the radiator and have had good results. Frozen boost has some small ones that would work well for this. It adds more volume to the system also. I'm going that way this summer. One is 5.75 by 11 by 2inches for 59$
Old Feb 28, 2016 | 02:02 PM
Crissus's Avatar
We dont do many back to back runs here in Germany... Im a Autobahn Driver... thats where i need the power... I have already CWA100 pump (extremely strong pump) and will add another HE + Split cooling soon.
