Guys with front lips...
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
How do you jack your cars up? I've been thinking about getting one of those godhand lips, but then I raised up my front end to check out a little rattle, and my floor jack BARELY fits under the fully raised car as it is! How do you guys with lips raise your cars?
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
I just raise my cars air suspension a the way and never have a problem really getting on a lift or using a floor jack.
But 2x4s when needed if the above doesn't work
e55
harbor freight has a couple decent jacks look for item #61282.it's 50% off right now.it as low as 2 3/4" and goes 20" high.i've had mine for over 2 years and use it 3-4 time a month.stay away from their light weight aluminum ones.they don't last long and the wheels are junk.
2x4s, low-pro ramps, low-pro jack
But then you can't put jack stands at the factory lift points...
I use jack pads at the factory lift points.
Attachment 271998
Attachment 271998
