DIY intake manifold gasket replacement
07 CLK550
Is there a link to a DIY link for intake manifold gasket replacement? I was getting codes P0171 and P0174. Took it to stealer and they told me I needed a new intake manifold and quoted me a almost $3500 bill. How does an intake go bad with only 58K miles. It just sits there. Didn't sound real to me so I decided to go the cheapest route first. I prefer to do my own work anyway so I don't have a problem getting in there and doing it. Just need a little help. 07 E63 AMG Thanks
PLATINUM SPONSOR
That can be a vacuum leak or bad 02 sensors as well. You need to hook up STAR somehow and dig deeper than going by the generic code readings.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Bump
Bumping this thread because I'm throwing the following codes:
P2187 System Too Lean at Idle Bank 1
P2189 System Too Lean at Idle Bank 2
P0171 System Too Lean Bank 1
P0174 System Too Lean Bank 2
If anyone knows of a DIY to remove and replace, specifically, my W211 E63 intake manifold, I'd like to take a look at it.
Thanks in advance-
Thanks in advance-
Received 1,499 Likes
Thanks in advance-
Thanks in advance-
https://www.startekinfo.com/StarTek/subscribe.jsp
https://www.ebay.com/itm/Mercedes-WI...c/282820670774
benzokirk (11-18-2018)
