Right rear suspension dropped fml
Hey guys. i think my right rear suspension dropped.![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
What exactly do i need to buy (part name)
Where would be the best place to buy
New or used?
This is my first MB and im learning...
Idk what would i do without yall, thank yall very much
New or used?
Check to make sure your rear airmatic sensor is still in place before ordering the airbags. Another member just recently had his rear drop and it turned out to be a plastic clip that cost less than a dollar.
Good point but that would cause both sides to drop, not just the right.
1999 MB C43 2004 E55 AMG, 2004 Suzuki GSXR, gl63
Is the sensor your referring to the ride height sensor? My one side seems to be dropping more then the other (rear) are these two connected via air lines? or is the sway bar just pulling the other down making it seem like its deflating…. It happens after about 12 hours or so it standing. Im thinking its a leaky air bag, won't know till my mechanic has time to take me in. Just trying to do some research before I take it in.
PLATINUM SPONSOR
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Can't say that I do. Although I do here it cycling a couple of times to raise it when it's been stationary for a while. Has anyone had problems with any of the plumbing in particular? (Air hoses ) trying to find a point to start at.
I had the hose leak around the fitting...easy fix...
Mine also drops in the rear after being parked for a while. I always thought it was normal, but it has been happening sooner these days. Guess I have a small air leak I need to look for.....
Also, if you do end up having to purchase the Arnott set, Advanced Auto sells it for $5 more than Arnott, but you can usually find a coupon code that drops the price $50 or so.
