removing rear resonator
Old Dec 3, 2013 | 07:23 PM
OZZYAMG's Avatar
03 W211 E55
Hi
I am going to remove the rear resonator in the picture below and just use the standard rear mufflers for now. Eventually I will fit some used C63 mufflers.
1) Does anyone know if the exhaust gases mix from each side of the engine in the standard rear resonator?
2) Can I replace the rear resonator just with 2 straight pipes or should I use a x over pipe?, is one way better than the other?
Regards,
OZZYAMG
