Sputter/Hesitation between 3.5K-5K RPM
Any ideas?
However, I didn't see any wheel being lower than another or stuff blatantly indicative of airmatic strut failure. Moreover, once the car has warmed up, this error doesn't come back on start up. Ie. morning start = error. Drive for 5-10 minutes to warm up. Restart car = no error.
Thoughts? Is that the air compressor having an issue?
I was using K&N filters and believe it or not, that was the freaking issue.
All kinds of tests were run and finally they spotted the K&N's and pulled them and replaced them with the factory ones and it stopped and has been running strong since. Possibly the K&N's was letting too much air flow.
I never would have guessed it, Always thought the more air flowing the better !!!
Good Luck in finding the fix. stevieg
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Tonight I did a few pulls and noticed the same symptoms.
However, it only happens when in gear. I can rev in neutral to redline no problem. It also feels like it's in the back end by the diff, not from the front of the car. It almost feels like there is a difference in the driveshaft spinning vs. diff spinning, and the car buckles every so slightly but surely and rapidly between 3700-4300 RPM - almost like a misfire.
Has anyone experienced this?
