Supercharger belt tensioner replacement help
Fellas, the supercharger tensioner in my m113k needs to be replaced. It barely holds the SC belt tight and the whole thing squeaks like an old Alvin and the chipmunks record. Ive searched this forum for a diy thread but can't find one. Was going to buy Shardul's pulley set, but i'm needing to replace the tensioner first. Looks fairly straight forward but I don't know about torque specs, etc. Any help here would be awesome. I'd like to take pictures as I go and make a diy for this forum, but i think I need other members help.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
![](https://dl.dropboxusercontent.com/u/25091240/Kompressor%20Tensioner/104071856.jpg)
1 Remove poly V-belt of compressor (2)
2 Unscrew bracket of compressor cooling pipes
- Bracket for charge air cooler water pipes:7 N.m (For Engine 113.992)
- Bracket for charge air cooler water pipes:14 N.m (For Engine 113.990/991)
3 Unscrew bolt (4) of tensioning device of supercharger (3)
- Self-tapping bolt of belt tensioner to timing case cover
- Thread not pre-tapped: 35 N.m
- Thread pretapped: 25 N.m
- Bolt of belt tensioner to timing case cover: 35 N.m
4 Take compressor tensioning device (3) off timing case cover together with tensioning pulley (1)
5 Install in the reverse order
QUICK 55, excellent post! Thanks for the help...Have you ever heard of tensioner failing like this??? You hear alot about the bearings but not about the whole sha-bang..
