Just how accurate are our oil level sensors?
Old Dec 20, 2013 | 08:40 AM
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
Did my change last night and gave up after like 4 tries to get the sensor to actually tell me something I wanted to hear. I got her up on the ramps, drained both pans, then put 8 quarts of Mobil 1 0W-40 in. Started her up, backed her down, and immediately pulled her into the garage (decently level) and let her sit for 5 minutes. Initial level: 6.1 Quarts.
Added 1/2 a quart, fired her up, let her idle for 5 minutes, then shut it down and let it cool for 5 minutes. New level 6.8 quarts. Grrr. Added another 1/2 quart, which now totaled the 9 QUARTS that I believe is the factory recommended fill. Performed the steps again and it shows 7.2 Quarts, yet I KNOW I added 9 Quarts. I don't want to overfill. Should I just assume the sensor is old (81,000 miles on my 05), or maybe since I'm STAR lowered the car sits at an angle possibly? She seems to be running fine, but I figured I'd ask since I'm paranoid as hell
Thanks gang.
Old Dec 20, 2013 | 09:00 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Mine is real accurate but sensors to get weak.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 20, 2013 | 09:13 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
OOOOO don't over fill it. You might want to order the dipstick tool.
Old Dec 20, 2013 | 09:28 AM
novae500's Avatar
W211
if i recall correctly, the difference in what you put in and what is read is the rest of the oil is in the torque converter/other oil pan. But since you know you completely drained the oil and put 9 in, you should be fine.
Old Dec 20, 2013 | 10:24 AM
typhoon43's Avatar
There better not be oil in my Torque converter lol!
That would be ATF.
9 Quarts is 9 Quarts, and that's what's in my engine. Screw the sensor at this point.
Old Dec 20, 2013 | 10:38 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you will be fine with 9 quarts don't worry about it
