SBC INSTALL REPAIR AND QUESTIONS THREAD
as some sbc pumps are reaching the 10 year expire date for free replacement. many consumer may turn to used sbc pumps for installation.
Started this thread for anyone who has info about install prodcedures and coding information.
from what i have learned if you have a star diagnostic system with developer mode. installation of a used sbc pump might be possible.
there are many different part number for the sbc pump with many different software versions.
in developer mode if might be possible to copy the dump file software in the sbc pump ecu then transfer file to the used unit by erasing the dump file software in the used unit and the transfering dump file software from old sbc unit to the used unit.
in developer mode there should be no need for scn coding.
im not sure but i think people and indie shops have problems coding new units because they try to code in the regular star menus. i can cause problem because of different software version used through out different units.
also one thing im comfused about when sbc has reached exceeded number of pedal accuation (error code c249f) is if you get the white visit workshop screen (where you still have normal braking) or the red warning brake defective (where you lose 90% of braking ability).
in developer mode you have the ability to reset the counter.
after resetting the counter does this get rid of the white warning only or does it get rid of the red warning also.
also has anyone ever replaced the carbon brushes on the sbc pump and if so could you post the procedure and or where to get the carbon brushes for the sbc pump.
if you have info and diffferent sbc pump compatibility with different cars and years please post
Reviving an old thread. Did you ever find the pump motor brush part number? My car is on its 3rd new mb sbc unit, I'm rebuilding this one. If you haven't, stay tuned for part numbers.
what parts are needed for a rebuild?
adabuf (01-22-2018)
I was hoping someone would have some solid info on this ... our cars are getting older now. The SBC is the part I am most afraid of failing, cos when it does, you have just about no brakes. With as much performance as our cars have, this would be extremely dangerous. I usually try to replace things before they actually break, but these SBC units are so expensive .. not exactly a maintenance item.
Apparently Bosch sells remanufactured Electrohydraulic units. Don't know if anyone has tried this yet. It would make a lot of sense to do this especially from the manufacturer. Should be much cheaper than a new one.
http://de.bosch-automotive.com/en/pa...ms_2/ehb/ehb_1
Bba reman offers a rebuild service in the neighborhood of 400 with a warranty. I'm pretty certain that it would include disassembling the valve block to check for debris, and replacing the motor brushes, and probably a new accumulator. Considering the motor does all the work of building pressure, that would be my first concern.
Nice ... I was actually going to mention BBA Reman. I have used them on a Passat's ABS module years ago. I checked their website a while ago but it did not mention SBC rebuild/reman. They have excellent service from my previous experience. I checked just now and they are $525 + shipping.
I would NEVER recommend anyone install a used SBC (even if it is still good, it likely needs to be programmed for your car). Remans from Mercedes come with the latest programming (that is for your specific application, I would presume) so you don't have to go to the dealer or find someone who has their star linked to mercede's database for more programming (I would check with BBA to see if their units will have the latest programming for your application when they send it back).
Worth mentioning, after you replace the SBC, if you plug your car into an offline star das, it will say that you need to update the programming (as it does not know one way or the other since you are off-line) , but if you have gotten it from Mercedes, you can disregard (as it has the latest already).
Hope that helps,
Chris
Thank you for the information, it is indeed helpful. But why would you be inclined to get a unit from Mercedes when it lasts a little over a year? That'd be almost $800 a year in running costs for this. Personally, I would be inclined to get a reman from Bosch if possible.
Since you can buy the Re-manufactured units from Mercedes wholesale for about $800 ... I would be inclined to get the unit from Mercedes .... HOWEVER, I have (gotten 2 from Mercedes now) ... And while my original SBC lasted 10 years ... the replacement lasted little more than a year (but long enough to be out of the 1 year part warranty). Changing the unit is not particularly tough, but it is a bother.
Hope that helps,
Chris
Hope that helps,
Chris
adabuf (01-22-2018)
In general, the price difference between having BBA rebuild your unit and getting one from Mercedes would make me inclined to get it from Mercedes so that I know it has the correct/latest programming.
HOWEVER, since my replacement that I got lasted barely more than a year, I would explore the BBA option were I to do this again.
AND worth pointing out, Mercedes ONLY supplies Bosch Re-manufactured units (for this application at least) SO, if you have a source for the Bosch reman that is cheaper (and/or has a better warranty) than Mercedes wholesale then you may want to go that way assuming they come with the latest programming (I just checked with VIC at Husker whom I get the best pricing from and they have the SBC for $805 plus $153 core).
So to recap
I have NO reason to suspect that you will have any better luck with a Bosch reman than a mercedes supplied (Bosch)reman .... which in my experience (and that of the 2nd poster is this thread as well it would seem) is not as good as the original .... SO, I would check out the warranty of BBA and consider that option
my $.02
Chris
I can't speak for every application, but the applications I've bought and checked for have had only remans available. Have your VIN handy when you check as they can't find you any useful info without it.
Cheers,
Chris
Cheers,
Chris
BBA WARNING!!!!!!!!!!!!!!! Its not a reman!!!!
I have just got off the phone with BBA and for 525$ plus shipping all they do is clear the C249F check operating time code, NOTHING ELSE. They are doing no other service to the unit. If you just want to clear the code there are tools you can buy on ebay for 30$ that will do the same thing. You are all welcome I just saved you 500$ ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
BTW I am NOT recommending this procedure above as a solution, just providing the info. For my car I think I will be looking for a Bosh reman unit from a vendor with a lifetime warranty, and yes there are some out there
Clearing the code can be done in star also, however if you do it don't reset the counter to 0 that is not good but many have put it at 50%. The sw is made to go bad much before the actual unit is bad
