oil leak from back of engine
Old Dec 30, 2013 | 05:24 PM
venomsE55's Avatar
E55 AMG
any common oil leaks from the back of the engine when the car sits. it just started and leaks when the car is parked, it was sitting in the garage for about 2 weeks.
Old Dec 30, 2013 | 05:30 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
rear main seal
Old Dec 30, 2013 | 06:37 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Originally Posted by shardul
rear main seal
This. Thankfully mine was covered until the extended warranty.
Old Dec 30, 2013 | 07:26 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Check the color. If its green/yellow to red it could be a trans connector. The red fades out over time and the trans fluid turns a green/yellow color. Oil is well obviously yellow to dark brown depending on age. That would mean a rear main seal.
Old Dec 30, 2013 | 10:45 PM
venomsE55's Avatar
E55 AMG
i was hoping it wasn't that. any idea of what that cost to repair?
Old Dec 31, 2013 | 03:56 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
Definitely rear main seal, had mine done last year, make sure you replace the plate and all new bolts too
Old Dec 31, 2013 | 07:33 AM
novae500's Avatar
W211
Dealer is over $1200. Indy shop quoted me $1,000
Old Dec 31, 2013 | 05:07 PM
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
Bummer. If mine ever goes out, I'm installing a 3K stall converter at the same time.
Old Dec 31, 2013 | 05:10 PM
3BNick's Avatar
2006 E55
This is my logic. Mine has started to seep a little and i figure I'd put it off until I can get my hands on that stall. One of those "while i'm in there" mods.
Old Dec 31, 2013 | 05:27 PM
venomsE55's Avatar
E55 AMG
now why did you guys have to go and put that in my head.
Old Jan 2, 2014 | 06:29 PM
venomsE55's Avatar
E55 AMG
after a second look, it might be trans fluid. any common leaks in the trans?
Old Jan 2, 2014 | 06:37 PM
stockC43's Avatar
Trans electrical connector. Check the color like I previously stated. Easy DIY and around $25 in parts.
Old Jan 2, 2014 | 09:59 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
Also could be as simple as a new oil drain plug and crush washer not being used during past oil changes
Old Jan 2, 2014 | 10:04 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
There is a recall out for this I believe. I replaced mine without knowing. Check if it has a recall/service bulletin for this issue and see if the job was done by Mercedes. I could've gotten it done for free. I only found out when my fuel senders were leaking and asked Mercedes to check on outstanding work that needed being done
