Jerking Tranny
Old Feb 8, 2014 | 08:34 PM
O-55's Avatar
2005 E55, 2009 VW GLI
Originally Posted by p30amg08
UPDATE- My car has been with the dealer for a few days. It just was not sitting right with me that my tranny is so jerky from 2nd to 1st. the updates they did worked for a few weeks but then again back to the jerk...1st time to the dealer they were unable to "replicate" the jerk and reset software and changed me $250. This time I told them keep the car overnight, and I will come by 7am when they open and sit with the SA and his Manager and "replicate" the prob for them. I went it and, was able to successfully replicate the issue. They agreed that it was not normal. Today I got a call from them saying that it is the Transmission Valve Body, and that it needs to be replaced..$1800 or so he said. Lets see if this fixes the issue. Will keep you guys posted.
O-55, Whats ur update bro? All Good?
I have not had a chance to wrench this week. I probably will not be able to get to it until next weekend. Your 722.9 should shift beautifully after the dealer replaces the VB, conductor plate, and TCU. Keep us posted.
-Oscar
Old Feb 11, 2014 | 03:02 AM
nardeezy@yahoo.'s Avatar
E63 AMG
When my car is cold, the shifting from 2-1 is sometimes rough in sport mode. Comfort mode is ok. I've had the dealer troubleshoot but they could never replicate.
The 2-1 shift harshness is more noticeable when driving like an old lady. When driven aggressive, it shifts smoother. Not sure if the car is thinking "Hey I'm in sport mode, the driver is going to drive aggressive" and the initially 2-1 shifts are rough but then smooth out once the car learns that you're driving like an old lady. My SA also mentioned the possibility of the valve body but didn't mention it going bad.
Old Feb 11, 2014 | 03:47 AM
goktu's Avatar
03 E55
have the same problem and droning sound got more so I took mine to dealer and waiting impatiently what they'll say
Old Feb 12, 2014 | 08:09 AM
p30amg08's Avatar
08 E63 AMG P30, 2013 S550, 09 E63, 14 E63 S Wagon, 14 E350 Wagon(current), 13 C63 P31 (current)
Update.
I got the car back last night after 6 days, (Damn I missed it) so the dealership replaced the valve body, and did a complete transmission flush. (it was done on schedule at 40k and now at 61k. Car feels awesome now. No jerk from 2 to 1, buttery smooth!! Finally! Drove about 50 miles last night from grandma driving to burning rubber, transmission took everything I threw at it no issues.
Old Feb 12, 2014 | 08:27 AM
goktu's Avatar
03 E55
Update.
that's nice.
mine has oil leak from tranmission, and dealer says that because of oil preessure loss this may happen too.
I'll wait and see
ps: nearly same kms mine was done at 50k now it's 65k
Old Feb 12, 2014 | 10:01 AM
p30amg08's Avatar
Originally Posted by goktu
that's nice.
I'll wait and see
I am sorry to hear that man. I know these dealers are not cheap
Old Feb 13, 2014 | 01:58 AM
  #32
Kropf's Avatar
2005 E55 Black, 2007 GL450 Carneol Red
... It just was not sitting right with me that my tranny is so jerky from 2nd to 1st. ... This time I told them keep the car overnight, and I will come by 7am when they open and sit with the SA and his Manager and "replicate" the prob for them. I went it and, was able to successfully replicate the issue. They agreed that it was not normal. Today I got a call from them saying that it is the Transmission Valve Body, and that it needs to be replaced..$1800 or so he said. Lets see if this fixes the issue. ...
... so the dealership replaced the valve body, and did a complete transmission flush. ... Car feels awesome now. No jerk from 2 to 1, buttery smooth!! Finally! Drove about 50 miles last night from grandma driving to burning rubber, transmission took everything I threw at it no issues.
I'm not sure if G-AMG at BenzWorld was talking about the same problem, but while I was replacing my Conductor Plate recently and referring to his excellent http://www.benzworld.org/forums/w210...tor-plate.html, I noticed these quotes that may be related:
"Since I had the Valve Body out, I went ahead and replaced the Regulator Pressure Control Valve Spring (another common failing part.. causing ROUGH shift from 1->2 and 2->3)."
"The spring is underneath THIS Cap."
"Measure the Spring, for a length of 2.055" or greater.. to make sure you haven't 'lost' a piece of coil floating around in the valve body. The springs are known to break."
"Pressure Regulator Spring (Yes, those Idiots at MB change out the WHOLE Valve body, rather than the stupid $8 spring-- thus, NO MB number) Sonnax 68942-01 You should be able to get it at your local Transmission Supply house."
(I didn't have this rough shift problem, so I didn't open my valve body.)
Old Feb 14, 2014 | 08:09 AM
  #33
p30amg08's Avatar
Dang I don't know if they changed the spring or the conductor plate. Just the valve body and complete transmission service.
From what I am gathering there all separate and not part of VB?
Old Feb 15, 2014 | 12:15 AM
  #34
Kropf's Avatar
From what I am gathering they're all separate and not part of VB?
I have not seen what a dealer says is the VB, but I imagine that it would include all such springs...
Old Feb 25, 2014 | 07:14 PM
  #35
O-55's Avatar
A bit of an update to report. I was originally going to reassemble everything with the new conductor plate, but I went ahead and reused my old conductor plate with the new TC solenoid in order to provide more accurate results.
Result: The jerk/buck no longer exists. I was not able to log many miles at first because my supercharger went **** up shortly after the repair. I replaced the supercharger this past weekend and then drove around in the car quite a bit. The harsh shift from first to second gear is no longer there. What I have now is the symptom FinanceMike expressed earlier in this thread (the awkward RPM drop while still in gear right before a gear change), except I have it when changing from first to second and second to third. I believe it is due to poor signal strength between the conductor plate and solenoids, but I cannot be certain at this point.
I plan on wrapping up this saga Sunday morning. I'll report back after replacing the conductor plate and logging more miles.
Also, to those who think their tune is the culprit, my symptoms occurred when my car was stock and continued after the car was tuned (ECU and TCU). Torque converter replacement did not yield any improvement either.
-Oscar
Old Feb 25, 2014 | 09:17 PM
  #36
p30amg08's Avatar
Good info sir, keep us posted.
Old Mar 27, 2014 | 12:09 AM
  #37
C3Duece's Avatar
2002 C32AMG
https://mbworld.org/forums/c32-amg-c...em-solved.html
Old Mar 27, 2014 | 09:25 AM
  #38
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
FWIW you can trust G-AMG he is a highly respected member over at BenzWorld for at least the last 5 years. and yes that spring on the 722.6 in the W210 fails all to often, yes we (W211E55) have that spring too
