Coolant Flush DIY?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I'm thinking about flushing my coolant and I was wondering how many gallons will I need? Is there a DIY how to flush the coolant because I've searched but no luck.
TIA
TIA
PLATINUM SPONSOR
Since I live in a hot climate, I just drain the coolant and put one gallon MB coolant back in and the rest I use distilled water to top off. Coolant totals can very based on what cooling mods you have.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Is there a bleeding process to get any air bubbles out of the system?
Personally, I haven't changed out the coolant, but here's the factory instructions for our 113.990 (E55 AMG Kompressor engine) for reference. There's probably a cheap DIY method without having to go the dealer tools method for bleeding the coolant--hope others chime in.
Of note, in the factory instructions, don't follow every step if the Model 211 isn't listed in it.
