torque spec for fuel pump ring?
Old Feb 13, 2014 | 12:12 PM
spazmoid's Avatar
2018 E63s, 2004 E55 AMG
Does anyone know the tightening torque spec for the fuel pump locking ring?
Old Feb 13, 2014 | 03:00 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Do not believe there is a spec on that plastic ring because simply there is not a socket to fit it. Since plastic when clean will bind I would suggest some (little) silicone grease, NOT THE SILICONE SEALANT. Place a small amount on the first threads of the ring and "two" hand tighten, best results would be to do it when the weather is warm ,freezing cold plastic is another story.
Good Luck.
Old Feb 13, 2014 | 03:22 PM
spazmoid's Avatar
I just found it in the service manual actually. It's 80Nm, or about 60 lb-ft. I have the special tool for it so it's actually possible. If you don't have the tool then your method would be the way to go for sure.
Old Feb 13, 2014 | 05:05 PM
Critter's Avatar
Would you be so kind as to post a picture of this tool/ socket, I have never seen one before.
Old Feb 14, 2014 | 08:26 AM
spazmoid's Avatar
Sure, search this item number in ebay, 350700106848
Old Feb 14, 2014 | 10:47 AM
Critter's Avatar
Thank You Spazmoid, I stand corrected.
Maybe install without using this tool and doing it by hand could lead to a leaking seal condition?
