::ECS Tuning:: 722.6xx Automatic Transmission Wiring Harness Spacer Kit
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Kits Starting At - $17.31*
It's no secret that the wiring harness spacer on the Mercedes 722.6xx Automatic Transmission is prone to leaks. Over time, transmission fluid will begin to find its way past the seals on the wiring harness spacer and eventually wick up the wiring harness and get into the transmission control module.
Before this failed part causes more damage than a few spots on the garage floor, replace it using ECS Tuning's Automatic Transmission Wiring Harness Spacer Kit.
This kit includes the following items:
One (1) Automatic Transmissin Wiring Harness Spacer
One (1) Quart Of Automatic Transmission Fluid (Meets MB Spec 236.14)
One (1) Transmission Dipstick Tube Filler Cap Lock Pin
*Price subject to change.
While I'm worried about my wiring harness spacer I'm also worried about my credit card info with you guys. You don't have the best rep when it comes to that
2012 SLS AMG
Shifter,
Yes, this is just a factory connector in these kits. The Genuine Mercedes-Benz kit has, of course, a Genuine Mercedes-Benz Spacer (available as an individual component HERE), while the Aftermarket Kit has an Aftermarket Spacer (available as an individual component HERE).
Both of the Spacers are of the latest Mercedes-Benz design to correct the problem of transmission fluid leaking past the seals, which will eventually wick its way up to the transmission control module.
The kits are just a simple way for you to get all of the components you need to replace the Wiring Harness Spacer without looking all over for all of the individual components.
If you have any more questions, please don't hesitate to post or send a PM!
