Some parts came in...and UPD performed surgery
Old Mar 7, 2014 | 09:42 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Originally Posted by G_Money
How much oil should be in the supercharger? Assuming some is burned off, putting the same amount in as you took out could potentially leave too little in the SC, right?
Here is a DIY posted in the past.
https://mbworld.org/forums/w211-amg/...refilling.html
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 7, 2014 | 10:07 AM
cm60k's Avatar
This also could HELP:-
ZAYED,,,
