IC pump changed, but ..
Old Mar 3, 2014 | 10:13 PM
mAMG's Avatar
SL55 2003
Hi all,
I live in a hot area, and few months back, I have experienced drop in power and supercharger not engaging. I knew it is the IC pump from reading here. anyway, the weather started to be cold, so i lived with the bad/weak IC pump for one month more.
1 weeks ago, I changed the IC pump with 010 Bosch.
The problem still exists, high intake air temperature!, yesterday it was cold (20C= 68F), and the Intake air temperature was 190-198 F !
The mechanic did not bleed the system i guess , would it be the problem ? the car is stock.
Thanks.
Old Mar 3, 2014 | 10:27 PM
hayseed's Avatar
04 e55
How do you know what it intake temp is? Thx... Does the pump have power?
Old Mar 3, 2014 | 10:41 PM
mAMG's Avatar
SL55 2003
I used ELM OBDII to check the IAT. Yes it should, i guess i have to recheck it again.
Old Mar 4, 2014 | 07:06 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
System still has air in it. You need to bleed it
Old Mar 4, 2014 | 10:11 AM
ArmoE55's Avatar
2006 E55
shardul, of course, is spot on.
This exact situation happened to me with my first E55. If you install the IC pump and do not bleed (or properly bleed) the system, the car will be a dog.
Bleed the system again.
Old Mar 4, 2014 | 10:32 AM
kponti's Avatar
E63
A Mercedes tech told me that without the cooling split mod, a couple of days of driving (heat up, cool down, rinse and repeat) will be enough to completely bleed the system. Unless your relay is not responding properly. In that case, replace the relay or keep trying to bleed the system
Now I gotta find out what relay that is and where its located. He stated that they tend to get stuck and when hot and will either leave the pump running all the time (good for power) or shut off for extended periods of time (dog in heat)
Old Mar 4, 2014 | 11:51 AM
Speedriven1's Avatar
Speedriven
Shardul is right, the system needs to be bleed and in theory your tech is right but that's just laziness.
Old Mar 4, 2014 | 12:10 PM
kponti's Avatar
E63
Well you cannot just say that and leave me hanging???
What relay is this and where is the location? Mine is definitely shot cos sometimes I have bountiful power and sometimes I am barely faster than a 335i (108-110mph trap speed).
Old Mar 4, 2014 | 12:18 PM
ArmoE55's Avatar
2006 E55
What else is there to explain?
Bleeding the system takes 5 minutes, not even.
Old Mar 14, 2014 | 04:16 PM
mAMG's Avatar
SL55 2003
I've bleed the system (15 min, some water and bubles came out), and till the moment the supercharge didn't shutdown.
However, the weather temperature is around 87 F and the IAT is 180 F after few pulls.
Is that normal ?
I read somewhere that the IAT should be 20F degree more than the weather temperature, is that true ?
Old Mar 14, 2014 | 04:23 PM
shardul's Avatar
yes that is normal on car with stock cooling and the mentioned ambient conditions.
Old Mar 14, 2014 | 05:58 PM
mAMG's Avatar
SL55 2003
The car feels faster at lower IAT temperature, when IAT raises , it feels slower so that my friend with W210 E55 is as fast am I. there is lag of supercharge engagement as well.
If I changed the intercooler with EC or PLM, would that make a huge change in IAT temp ?
Old Mar 14, 2014 | 07:59 PM
black06c230's Avatar
mgLipGD
a larger HE would always help plus with the bumper off you can double check the IC pump. I would go with the PLM for ease of install.
Old Mar 14, 2014 | 08:03 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Split the cooling system.
Old Mar 14, 2014 | 08:24 PM
mAMG's Avatar
SL55 2003
Does it require any modification to install it ?
What do you think about the FTP spilt cooling systems ?
Old Mar 14, 2014 | 08:26 PM
mgLipGD
nothing to mod on the PLM one, just bolts to the OE holes and the cooler bolts to it under it. No zip ties like some others to hold it in place.
Old Mar 16, 2014 | 10:36 AM
macko's Avatar
e55 2005
Check fuse, maybe new pump doesn`t work.
Old Mar 17, 2014 | 09:54 AM
1SickCLS's Avatar
CLS55 AMG
run the pump to a switched 12v source. I had a similar issue, but I never could get my pump to engage no matter the temp. After installing a bigger heat exchanger and the always on pump, my 1/4mile went from 109mph to 118.5mph. It was a serious bump in cooling efficiency.
