What is the highest boost in a 55k?
Old Mar 9, 2014 | 01:12 PM
blackbenzz's Avatar
haters crazy
How much boost are you running and do you have any limp mode issues? Apparently some people are running into limp mode issues higher than 17 PSI
Old Mar 9, 2014 | 04:09 PM
SPatykAMG's Avatar
W211 E55
I peak at 16.5 so I must be lucky that I'm running right up the problem point
Old Mar 9, 2014 | 07:13 PM
black06c230's Avatar
mgLipGD
16.5 here and no issues either
Old Mar 9, 2014 | 07:35 PM
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
Hitting up to 17.4 psi (185 crank/supercharger pulley) and hitting failsafe. Splitsec map clamp set to 4.25v and going with BIP Tuning to fix what other tuners can't. No failsafe, brother. ..
Old Mar 9, 2014 | 09:33 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Damn all of you guys run more boost than I do
Old Mar 10, 2014 | 05:24 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Had mine in the 18-19 psi range almist on a daily basis with no issues at all. Stock MAP sensor and im still running the canned tune that Steve @ Weistec gave me to get the thing running, no custom dyno tune yet.
Old Mar 10, 2014 | 11:43 AM
Denroll's Avatar
'06 E55
I was hitting 16.5 psi at sea level. Now I live close to 4,000 ft and I am hitting a little over 13 psi. 175 mm crank pulley and 80 mm fixed s/c pulley.
Bramage was hitting failsafe at 17.5 with 185 mm and I think an 80 or 83 mm upper.
Old Mar 10, 2014 | 03:33 PM
I'm not sure what my peak was but I when Jeremy and I did a road tune awhile back I recall him saying something about @ 15.1 it wasn't bleeding off any boost
Old Mar 10, 2014 | 06:26 PM
blackbenzz's Avatar
haters crazy
I'm making about 20.2psi and no limp mode. Some people get it at high boost and some don't. Trying to figure out what the difference is
Old Mar 10, 2014 | 06:41 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Where are you measuring? Manifolds or the Y-pipe location?
Old Mar 10, 2014 | 06:43 PM
blackbenzz's Avatar
haters crazy
OBD2. I'm not running factory sc
Old Mar 10, 2014 | 06:52 PM
Lenin's Avatar
haha. By now we all know that you are not running factory SC. I was asking because the placement of the sensor may account for some of the difference. I have seen a 2PSI difference between the manifold and the Y-pipe.
Old Mar 10, 2014 | 07:08 PM
How's the Weistec working out? Did you get all of the bugs out?
blackbenzz's Avatar
haters crazy
Post Intercooler
blackbenzz's Avatar
haters crazy
Long story. Still needs tuning
Old Mar 11, 2014 | 05:29 AM
I think the difference might be how long the boost levels are high.
EREBUS is throwing codes but he's mile racing, and spending 4+ seconds with the MAP maxed out IIRC
