Power Mirrors Not Working
So I replaced my mirror gaskets last weekend and now neither power mirror will adjust (either manually or with the memory button).
I double checked the connectors and they're solid and can't be swapped.
Any ideas what I broke? Do they need to be reset?
Update: So I manually moved the mirrors to see if they had any resistance and now the memory buttons work. I still don't have manual control over the setting of the mirrors.
1 Post
2006 SL65 AMG, 2014 E350, 2012 ML350 Bluetec
Do you have your passenger mirror set to adjust when you back up? If it does move when you go into reverse, I would check the mirror control switch, as power is getting to the mirrors. Well now that I say that, your memory controls work so yeah check the switch...
Mine wasn't working and I picked one up online for around $30-$40.
I hope that helps!
I hope that helps!
