Air Intake Y-Pipe...
My snaps on my y-pipe broke but I cannot seem to find a part number! Anyone have one laying around or might have a part number?
PLATINUM SPONSOR
I need your broken Y pipe please?
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Don't forget to get a Y/T-Fitting Gasket - the few dollar rubber seal that meets the Throttle Body and snaps inside the T-Fitting (whose clips snap off). All the gasket/seals I've seen are so old and hardened that they don't seal well - my '05 E55's actually had silicone slobbered in there to help it seal some sad day long ago. (Use EPC Group 52, Subgroup 'Air Intake' - my E55 is image #8, but the CLS55 is image 4, both CLS55 and E55K use the same seal/gasket 1121590080.)
The EPC note says the gasket/seal may be different but no such note that the T-Fitting varies.
Here's the EPC note regarding the Gasket:
Air Intake Tube Gaskets that apply to vehicles with M112 and M113 engines: The smaller gasket (93 mm OD, 81 mm ID) has part number A112 159 00 80 and the larger gasket (96.5mm OD, 86 mm ID) has part number A112 141 17 80 (optional with A112 159 01 80). Please measure the air intake tube to verify the required part. 08/19/2008
As noted by turbo97se earlier, it's best to check the EPC using your VIN. (It's free in the USA. https://epc.startekinfo.com/epc/ )
Looks like it's the same - at least comparing the CLS55 (219.376) to the E55 (211.076/211.276) : A 113 094 01 03
I got it from the dealer as now it comes as whole assembly rather than just y-pipe.
part number is 113 090 01 29
