--P0106-Powertrain faulty code-- thoughts??
P0106 Power-train
Manifold Absolute Pressure/Barometric
Pressure Circuit Range/Performance Problem
car runs fine no issue, had a slight rough idle at first than went back to normal... I cleared the code so we'll see if it comes back again but i did a bit of a research and i saw some saying it could be the MAP Sensor??? shown on link below
Part #: 005-153-50-28-M14
http://www.pelicanparts.com/catalog/...ELSENS_pg5.htm
Besides; (p0106) in somehow caused from air leaks between TB and kompressor or Y-pipe or TB gasket, this air leak interrupt the MAP sensor, which through that code to ECU, specially after 650 RPM,
if you have a contact cleaner, spray the suspected area to pointing-out the problem area,,
BTW; MB replaced the # from (Bosch)005 153 50 28 to (DC/R Japan)005 153 72 28, any idea why...??
ZAYED,
I took a wrong turn into a dead end street, when I stopped to turn around, the car simply would not go into gear, put in on R, nothing, put it on D, nothing, gave it gas, and it like I was in Neutral. Eurocharged did my TCU, I will let them know this happenned, it had never happenned before.
I don't know if both issues are related, but I hope neither happens again.
Have people find a solution to the hiccup?
Issues I've experience, no boost, and I do mean Zero boost, also, sometimes my car would have some pretty awkward cold starts, like it's not getting enough air, like it is gasping... Haven't swapped the MAP sensor yet, idle and boost issues come off and on very randomly.
Berti, how did you solve the problem?
Maybe this isn't your problem though but worth the check...
Did you ever experience your car feeling like it was gasping for air or idling weirdly on start up?
Thanks berti!
Yahh car had idle issues and than Cel..
Never seen it again
