Battery pic/visit workshop
Old Apr 24, 2014 | 12:14 PM
Harleyl7's Avatar
I did all my searching around the forum and what I've found is that it can either be the aux battery, main battery, alternator, or the voltage regulator. I just had my aux battery replaced and the visit workshop error didn't go away.
Should I just take it to the dealership and let them figure it out or keep replacing parts till it goes away?
Old Apr 24, 2014 | 12:52 PM
moosejaw's Avatar
none
replace parts as you go but first
check voltage at both batteries and alternator with a meter.
if all check out then.......
check fuses front and back
check voltage regulator at alternator
check BCM battery control module
Old Apr 24, 2014 | 01:03 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
If you have a multimeter, test your batteries. If they come up good, I would check the voltage regulator. I replaced mine a few months ago, took me 30 minutes and I got the OEM part for about $40 on RMEuropean.
The last thing you want it to be is the alternator, which is $400 and involves taking half the engine apart.
Old Apr 24, 2014 | 01:09 PM
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
Voltage regulator fixed mine after replacing the aux battery and testing the rear. It's a fairly easy fix, and is cheap. I'd do it.
Old Apr 24, 2014 | 02:04 PM
Harleyl7's Avatar
What's the right numbers for the batteries?
Old Apr 24, 2014 | 02:51 PM
G_Money's Avatar
~14 volts
Old Apr 24, 2014 | 03:33 PM
typhoon43's Avatar
Originally Posted by G_Money
~14 volts
With the car running
12.2-12.8-ish off.
Old Apr 24, 2014 | 07:11 PM
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
Get the batteries properly tested a mulimeter is not a 100% accurate test of a battery. If the battery has dropped a cell it will cost you an alternator eventually.
Shops that only sell batteries should have one of those accurate conductance testers some of them can test alternators aswell. This will give you a yes or no if the batteries are an issue.
Then look at the alternator if its melted at the back the rectifier pack has been overloaded. If you pull the voltage reg and its like the pictures on here that "might" of been your issue. But id still test everything else aswell while your at it as this ends up a compounding thing where it costs more and more money if you dont get it right the first time.
14v is with the car running on the MF display.
12.2 not running is about right when you use the MF display to tell you voltage as there is a voltage drop in the line between the batteries and that display. So its actually more like 12.6 at the battery with a multimeter.
Old Apr 24, 2014 | 07:43 PM
G_Money's Avatar
I thought if you had a bad cell your battery won't hold or take a charge?
Old Apr 24, 2014 | 08:02 PM
austingtir's Avatar
Might not necessarily always be a bad cell but the plates might not be conducting between one another properly. For example my alternator burnt up. These alt's dont usually just burn up for no reason. I looked at my batt voltage and got 12.7 after charging it back up. It held this charge fine and started the car fine. Yet i put it on one of these conductance testers as shown below and it clearly fails and is the reason my alt burn up.
