Stock Y-Pipe Hose Clamps
Old May 5, 2014 | 07:55 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
For those of you that have removed them for one reason or another are you putting the factory clamps back on or are you using a regular hose clamp?
Old May 5, 2014 | 08:43 PM
E55Greasemonkey's Avatar
This place is a joke.
The stock ones can be re-used. Unless you took them off wrong.
Old May 5, 2014 | 08:44 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I went back with quality regular hose clamps.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 5, 2014 | 09:37 PM
Brooke were there oval or did the reg circular ones work fine? I would use the factory clamps but I don't have that special little tool to remove & install the factory clamps
Old May 6, 2014 | 09:19 AM
PLATINUM SPONSOR
2003 CL55
Regular circle clamps will conform tot eh shape and look real n ice. Just buy the right length and use quality clamps. It will look great and fit well.
__________________
www.ultimatepd.com
