Another tire/wheel size question (spare tire)
2001 BMW 325 xi
I recently purchased an 05 that came with a collapsible spare tire. The seller of the care had a flat before he sold it and failed to inflate the tire before driving on it. As you can imagine, the spare is shredded. If I buy an OEM style front wheel and tire, will it fit on the back of the car in an emergency situation? Not looking to rotate 5 wheels, just looking for a cheaper alternative than purchasing another spare from the stealership.
'04 E55 AMG, '03 ML500, ‘13 BMW 528i
2001 BMW 325 xi
The wheel is fine, I was told that you couldn't buy the tire without buying the wheel. Scoto, I am interested in the the tire, PM with details please. Schnell!, thank you for the answer. I didn't know if the offset from the front wheel would work on the back of the car.
A full size front wheel/tire should fit in the spare tire well, but you'll need to remove the foam liner which the spare tire rests on...and you'll have to pop off the center hubcap off the wheel if you're using the screwdown.
