A tip for those installing the Belt Wrap Kit
Old May 28, 2014 | 10:47 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
If you're not installing idler pullies at the same time, there is no need to remove the upper left idler per the directions. All you need is something small to fit in the hole shown on the tensioner. I used an old bent radio antenna. Just rotate counter-clockwise until the hole in the front of the tensioner lines up with the back hole and insert your makeshift lock tool. In the pic below, the orange arrow shows the hole you are using and the blue arrow shows my bent antenna poking through the back.
For those wondering, the pulley is removed to allow easy access to this boss that will be used to mount the BWK bracket. This should save some of you a few minutes of work.
Old May 28, 2014 | 01:41 PM
Miniac's Avatar
E55 AMG
Thanks for the heads up.
