BWK bolt question !
Old Jun 2, 2014 | 01:52 AM
ss.dna02's Avatar
05 E55 AMG
BWK bolt question !
Im trying to remove the bolt from the double idler pulley and I cant figure out how
What size do I need for the double idler pulley bolt ???
Thanks!!!
Old Jun 2, 2014 | 03:10 AM
green1212's Avatar
2004 MERC E55
t50 torx
the double idler pulley bolt is a t50 torx. the tensioner bolt is a t40 torx. i know why couldnt both of those bolts be the same right?? see if you have a t50, and that should do the trick. not much room there, may consider removing that fan shroud out of the way. hope that helps.
Old Jun 2, 2014 | 05:08 AM
ss.dna02's Avatar
05 E55 AMG
Thanks!
Im alll done but I should tell you guys looking to get a BWK, make sure you have the tools needed. My Torx bits were too long and I had a hard time removing and installing the bolts on the kit because the ratchet would hit the fan shroud.
Old Jun 15, 2014 | 02:55 AM
ss.dna02's Avatar
05 E55 AMG
For those who have a BWK, what brand of torx bits did you guys use for the bolts?
I have craftsman and I could not fit it with a ratchet because it would hit the radiator shroud.
Old Jun 15, 2014 | 06:56 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I have a torx socket set from harbor freight but I had to remove the torx bit from the socket and then use a small box wrench on the torx bit.
Old Jun 15, 2014 | 08:43 AM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
Snap on/blue point 1/4" drive stubby. They measure a 1/2" tall!
Old Jun 16, 2014 | 12:31 AM
ss.dna02's Avatar
05 E55 AMG
I tried this but the wrench was not big enough for me to be able to apply enough force.
Any link to the Snap On stubby ?
Old Jun 16, 2014 | 09:07 AM
BagMan's Avatar
Maybe you can slip a small breaker bar / tube over the wrench for more leverage?
Old Jun 16, 2014 | 09:36 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
cut a small piece of a 8mm allen and use a self ratcheting wrench
Old Jun 16, 2014 | 10:12 AM
need4spd's Avatar
2005 E55 AMG
Or just remove the fan (takes 5min) and save your knuckles, and bunch of time.
Old Jun 16, 2014 | 11:32 AM
shardul's Avatar
+1
Old Jun 16, 2014 | 08:26 PM
211.070's Avatar
Here you go!
http://buy1.snapon.com/catalog/item....roup_ID=682316
Old Jun 16, 2014 | 08:41 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Fan shroud removal can save time, as you can get to all the bolts a little easier and it helps to put accesory belt back on. Just depends on what tools you have available. The CL and S class have about 3-4" of extra room between idlers and fan than E class.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jun 17, 2014 | 02:43 AM
OZZYAMG's Avatar
03 W211 E55
Hi
Which bolt is easier to remove from the bwk? (the double idller pulley to the left of the motor or the one to the right under the supercharger pulley)
Does the 8mm allen key work with either bolt?
Regards,
OZZYAMG
Old Jun 17, 2014 | 03:40 AM
green1212's Avatar
2004 MERC E55
the bolt to the right of the supercharger pulley was the easiest for me. made the mistake of not placing the belt inside so thought about the double idler pulley set to remove but i had already set the serpentine belt on all those pulleys and maze so went to remove the bolt right of supercharger pulley. more room is available there due to its indention to the bwk, and you are allowed to move it up to slid the belt inbetween without much disruption of the bwk. dont remember whether 8mm allen key worked but which ever allen key it is, its the same one for both bolts. at work, sorry. but definitely the "right bolt".
