non-linear feel to brakes
Old Jun 6, 2014 | 11:45 AM
Kelburn's Avatar
W211 E63
Just bought a CPO 09 E63, which had the fluids topped off. The brakes are not progressive or linear in their application. You apply pressure to a spongy feeling peddle and it goes from minimal braking to full-on in a fraction of a an inch. I think they just didn't bleed the brakes, so their is air in the line.
Could it be something else?
Not having owned a E63, is the brake pedal usually spongy?
Old Jun 6, 2014 | 03:59 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Sounds like it could be air in the lines but that is hard to do, unless oil lines were breached or tech did it with a fluid flush.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
