Lowering module - error
Old Jun 13, 2014 | 02:30 PM
blaferty's Avatar
2015 C63S
I had Programa ELM moved from '09 E63 to '07 E63.
The raise & lower function in center console no longer works, but it did when module was installed in '09.
Also get 'Airmatic' error in display. Shop cleared code but it comes back.
They contacted Programa, but they did not have an answer.
Old Jun 13, 2014 | 07:47 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
I would double check all the wiring, sounds like a wire is crossed and it is confusing the ECU causing the airmatic error.
Old Jun 13, 2014 | 08:26 PM
3BNick's Avatar
2006 E55
Agreed. Have them double check wiring. Perhaps one of the CAN lines has a bad connection.
Old Jun 13, 2014 | 10:04 PM
blaferty's Avatar
2015 C63S
Correction: The error on the display is not 'Airmatic' but 'Malfunction' with graphic of car & up arrow.
Additionally, the Adaptive dampening control does not work either.
Programa said some years/models can be slightly different, but he did not have solution.
Same tech did both cars
I'll have wiring checked one more time.
Old Jun 13, 2014 | 10:25 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Everything should be the same since both the cars are a w211
Old Jun 14, 2014 | 11:15 PM
FASN8N's Avatar
They SHOULD be the same, but don't some cars have 3 wire sensors and others 4 wire sensors?
Also, it seems like the original instructions had the color or pin # of a wire listed incorrectly and sent out new instructions at some point.
Just going from memory….
Old Jun 16, 2014 | 11:49 AM
goalie_k's Avatar
2012 GL350
07 and 09 are the same pinouts. You have a wire wrong or bent pin. Triple check the pins.
Old Jun 16, 2014 | 12:10 PM
blaferty's Avatar
2015 C63S
Thanks to everyone for replies. I will have the shop go back
& check wires & connections.
Old Jul 20, 2014 | 03:19 PM
Canuck11's Avatar
2007 E63
Did you find a solution? I have the exact same problem.
Old Jul 20, 2014 | 03:52 PM
blaferty's Avatar
2015 C63S
It was also causing the trans. to shift very hard. Wiring was apparently correct.
Shop removed the module. Dampening control, raise & lower function, and trans are back to normal.
Used STAR to lower car instead.
Old Aug 27, 2014 | 01:13 PM
*AMG123's Avatar
E55AMG
Hi guys, I am owner of an E55AMG'05. My car has an airmatic problem. The diagnosis gives these fault codes (5132-left side airmatic sensor/5142-right side airmatic sensor/5152-rear airmatic sensor)
Airmatic kompressor works fine up and down.
The problem is that car's left side is 12mm down then right side or opposite! (right side is 12mm upper then left side)
While we connect the car to diagnosis,we made felt and right at same balance but whenever disconnect from diagnosis and try to up or down the airmatic, the problem occurs again.
I think a wire contact to chasis,also deaits of the fault code says the same.
If somebody had the same problem,then help me where to start?
Thanks. I am sorry about my english,hope you understand well.
Note: sensors are fine,sockets are fine.
Old Aug 27, 2014 | 01:33 PM
FASN8N's Avatar
Have you tried checking all the wiring connections that control those suspension functions at the modules under the right side footwell under the carpet? Maybe moved to the otherside for non US cars...
My thought is maybe a lowering module was installed at some point in the past, uninstalled, and now maybe some of the wiring is not maintaining a good connection?
Old Aug 28, 2014 | 06:57 AM
*AMG123's Avatar
E55AMG
Thanks for your reply!
right side footwell? i didn't check.
Is it the pessenger side? I will try to check it out.
My car is usa car.
I will check some wires,connections and fuses today.
Car goes up and down,airmatic works fine but diagnosis gives right/left/rear sensor fault.Also there is 12mm difference between left and right side.
Is it normal,when i select up or down mode,or comfort/sport/advance mode,should it show in the monitor that changes?
thanks. (it doesnt show any changes in the monitor)
Old Aug 28, 2014 | 07:28 AM
FASN8N's Avatar
Sorry, when you apologized for your english, I assumed you had a non US spec car.
Yes, check the connections to the modules in the passenger footwell under the carpet and padding and see of there is any evidence of spliced wires from a previous lowering module install.
Yes it is normal for some variation from side to side measurements, you can always find someone or dealer with a STAR system to recalibrate the values if needed.
When choosing between comfort, sport 1, or sport 2 modes you should see a notification in your speedo display where all the other information is located.
My car is usa car.
Old Aug 28, 2014 | 01:32 PM
*AMG123's Avatar
E55AMG
I checked left side (drivers) of the car,but under the hood.
I couldnt see any box around footwell under the carpet, right or left side
My car is 2005 model,is there any other place?
you mean 'under the carpet' that should i forcely take the footwell and the carpet?
Old Aug 28, 2014 | 02:10 PM
FASN8N's Avatar
Yes under the carpet in the passenger footwell. Maybe this will help
http://www.renntechmercedes.com/www/...iles/mb_lm.pdf
Old Aug 28, 2014 | 03:36 PM
*AMG123's Avatar
E55AMG
thanks dude!
tomarrow morning im gonna open there,but what should i do?
just check the connections? checking is there any contact wires?
is there anything to do?
also there is some airmatic electronics in the baggage,should i do something there?
thanks
Old Aug 28, 2014 | 04:58 PM
FASN8N's Avatar
I would look over the lowering module instructions and then look at the wiring to see if there is any evidence of the wires being spliced or cut. If so, then make sure each of the modified wires are not loose and making good contact with the correct pin locations. I would think the airmatic electronics in the trunk are ok since you said everything else is functioning properly.
thanks dude!
thanks
Old Sep 18, 2014 | 04:59 PM
*AMG123's Avatar
E55AMG
i called the mb service and the service worker said,maybe it need to be only re-programmed by computer. And i would think to go and check everything in the mb service.
And guess what happent tonight!
my wife was driving with upper suspension mode and she called me,the car scrape to somewhere or floor. I just check the car and front side both and the lowest mode! i mean lower then the normal. especially right side(it was 1cm upper from the right) is scraping the bumper!
tomarrow i will go to bosch car service because they are close to me.
i can not drive like that.
car do not go up even a little.
what do you think? air pressure compressor? or still electronical problem?
this picture,i took a week ago. i checked but there was no wire problem,i cleaned contack wire to body.
Old Sep 18, 2014 | 05:13 PM
FASN8N's Avatar
Weird that both sides are down, if it was one side I would say one of the air struts failed. Rarely do two fail at one time. I would say you have a leak in the air lines or distribution block. If the compressor failed the rear would be down too right?
Old Sep 18, 2014 | 05:44 PM
*AMG123's Avatar
E55AMG
What do you say?
front right is really down then all other sides.
the module no works!
even a litte up or down.no work.
no fail code or warning on screen.
Old Sep 20, 2014 | 10:25 AM
FASN8N's Avatar
Looks like the right front air strut has failed or has an air leak in the line. Time to call Arnott for a replacement if it has failed.
Old Oct 16, 2014 | 11:12 AM
*AMG123's Avatar
E55AMG
Old Oct 16, 2014 | 11:19 AM
*AMG123's Avatar
E55AMG
b22/8 and b24/3 is front left
b22/9 and b24/4 is front right
b22/3 b24/s is rear
other datas are starts from front left,front right and rear.
i relized that front right voltage is acting opposite of other two sensors (front left and rear)
i mean if other two sensors voltage goes more,front right goes less, or opposites.
also its acceleration sensor is little less that others (2560mv vs 2520mv)
the 3 error codes are b22/8,b22/9 and b22/3 are front left,right and rear level sensors!
where could be the problem?
