Alusil, explained
Alusil, explained
I found a great article published back in 2008 my Tim Meara. Tim is/was a senior honing technician for Sunnen Technologies (the company that builds the best engine work machinery in the world, IMO) and had a spot light posting in Modern Machine Shop. Most will have a hard time following if you're not active in engine building, but it's still worth the read.
http://www.mmsonline.com/articles/ne...cylinder-bores
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Interesting. I knew that it was no easy task machining the cylinders on these engines but wow. I can see small time machine shops doing some serious damage to these blocks if there not well educated. I also found it interesting that you can press in a new alusil liner instead of steel.
