Frankenstein. (motor build)
Too much he said/she said, we like to have gopros on every car and a scout car.I'm not aware of any deck thickness differences, but I could check. I went through both head gaskets last year on a 55k motor so I certainly wouldn't say it's a 55 only weakness.
Seems the heads lifting may be more than just bolt choice?
Like I'm telling you something you don't already know...lol.
Good luck!!!!
Exactly. Lifting a head is an engine design being asked to do much more than even its design limits would provide. Meaning detonation.
Detonation is an engine trying to make, on an individual cylinder basis, 10 times more than normal. So a 50hp cylinder detonating is now trying to make 500hp worth of pressure, and the piston and head are not designed for this.
A 100% free of detonation motor is perfectly safe at very high power levels for lengthy periods. Its the detonation events (and pre-ignition) that end things.
Personally would check the torque on the other head to see just what the value is as I stated before ARP bolts have (at least in my case) seem to need additional torque checks to assure proper values. And yes head and deck surface needs to be aggressive enough to hold the gasket in place. I am still thinking the fasteners have loosened, hopefully I am wrong.
Rest assured guys I'll get the motor out soon, it's just been a little too hot lately and I don't need it on the road with all my other crap, lol. I'll keep this going and report my findings when I have them. At this point, everything is just speculation.
We wish you luck. I know I do. I am putting together a purposefully high compression motor in a different car AND adding boost. And running e85.
Just a small amount of combustion pressure in the coolant system! You are fortunate that it did not rupture at those speeds. It could have gotten ugly in the blink of an eye.
I am quite impressed with the build process. I would get the beast tuned in person next go around though. Find out what makes it happy, and healthy.
Some years ago, was at Watkins Glen and had a garage-mate with an FD (3rd gen RX7) Explained to the driver how the plastic overflow tank is problematic (they split) and should have it replaced right away. (had a number of RX7's and knew them very well) She dismissed me with attitude....next session out, it split, dumped coolant and she hit the armco, providing a quite large blue strip and dent down the car. Of course, didn't have to say, "I told you so."
That reminds me: anyone make a larger/thicker radiator for these beasts?
I have access to a dyno, this was the first day out.. a shakedown if you will. In person really isn't necessary, data is data. I'll be making a lot of adjustments to my tune before really leaning on it this time around
THIS run was on 100% e85? And you went less on timing? And you blew the head up?
What are your plugs? e85 doesn't like hot spots. It will pre-ignite. Plugs need to be like a pecker in the south pole - very very recessed.
The threads in the block were perfect, all studs were removed by hand. On one side, 6 out of 10 studs were stretched beyond what I would consider acceptable so the head lifted. On the other side, the top of the cylinder wall melted in between the combustion chamber and a water jacket (which was how the radiator blew up again). I purchased a CL500 short block, transferred all of my 5.4L components into the 5.0L bare block, dropped timing in the tune and she's been running fine ever since
What fuel was used during his this melt down? This is massive detonation and resultant hot spotting.
No one wants to blow a head gasket but you have to look at it this way. I was told buy a very good engine builder years ago and still live by it that "The head gasket is the "FUSE" in the engine". You would rather blow a fuse than the whole engine. So...if a "FUSE" pops....its telling you something is off/not right in the fuel,timing/tune aspect and you can go from there.
I guess that answered that. So you are running a 5.0 block now. interesting. I'm guessing you are using E85 daily?
5L crank on the left, 5.4L (N/A) crank on the right. The 5.4L M113k crankshaft IS slightly different from an N/A crank but I didn't think twice about using this one.
The block is practically identical. Main caps 1 and 5 do not use the side bolts, they're only 4 bolt mains, so the block not machined in those areas. There are a couple other changes, but nothing crazy and these are just test blocks really. If I were spending big money on a forged motor, I would use an E55 block but with my intended purpose I'd rather keep the costs down.
We have a local guy here who's trapping 140s in an HX52 k24 civic who always carries Autozone headgaskets with him. He'll go out with us some nights, pop a head gasket, and replace it before he drives home that night, and turn the gasket in for the lifetime warranty the next day. It's hilarious, but very cheap insurance.
5L bare block, the car has been on E85 only for about a year and a half. Recently, I've decided I want to start road tripping in the car again so I may be cleaning up the E85 tune and changing gears to refine a 93 tune for long distance driving.
I mapped a trip and I can get to ohio if I plan well enough for stops and have a tank in the vehicle of some sort with e85.
