Coil-Over shock settings? (BC / Others?)
When my guy did the BC Coil-overs, he thought they were 16 way adjustable, and put front neutral (8) and rears a little lower (5). Well, they are 32 way adjustable so this was way too soft. I have tweaked a little but am looking to see if anyone has already gone through the process and found the sweet spot. Right now my fronts are at 22 and rears are at 22. Rear is too stiff for sure. So before I go to the trouble of incremental change / test / change test.. I figured I would check with the experts!
Mine is set at 20 rear and 26 front from full soft. I had the front at 22 initially but it was too bouncy (I do have 18k Springs up front though).
