Help!!!!
Old Aug 12, 2014 | 12:01 PM
E55in253's Avatar
03 E55 AMG
Help!!!!
2003 E55 AMG 152k miles
problem
Was driving lights went dim started back firing as it died and went to the side of the road. tried to jump start it, it would not start
Took it in next day the alternator was done for got it replaced car still will not start
Changed the CPS
can hear the fuel pumps turn on when I turn the ignition to the on position
Car just cranks but won't turn over.
Any thoughts?
The Mercedes repair shop is trying to tell me my ECU is fried which I don't see how or why the car was able to connect to the Eurocharged software and flash to stock and my performance map
Old Aug 12, 2014 | 12:15 PM
E55Freak's Avatar
2005 E55 silver
are you getting fuel pressure at the rail? There is a cap on the front of the engine..if you don't have a pressure reader...have someone crank it and use a screwdriver to push the valve in..it should spurt some out...make sure the engine is cold!!
Old Aug 12, 2014 | 12:59 PM
E55in253's Avatar
03 E55 AMG
Just checked that and fuel came shooting out
Old Aug 12, 2014 | 01:34 PM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
So you have fuel. How about ignition? And who changed the CPS sensor? Crank position sensor not the camshaft sensor right?
Old Aug 12, 2014 | 01:35 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
What voltage are you seeing on the instrument cluster with the car off?
How old is the battery and the plugs in the car?
Old Aug 12, 2014 | 04:18 PM
James M's Avatar
03 E55 AMG
problem
Changed the CPS
Any thoughts?
Same thing happened to mine a few months ago - I got an 'ESP malfunction, visit workshop' message on the dash, so I put it on a flatbed and off it went to my indy. He called the next morning to ask why I had the car delivered because it started first turn and he could not find any codes on his MB diagnostics. He kept it for a week and it ran perfectly. I bought a spare CPS just in case, but the problem has never resurfaced. I would strongly advise against the 'ECU fried theory' because A: they are ridiculously expensive and B: I have never heard on one going before. Speak to Shardul - he is awesome at this kind of stuff.
Old Aug 12, 2014 | 04:19 PM
James M's Avatar
03 E55 AMG
problem
Changed the CPS
Any thoughts?
Same thing happened to mine a few months ago - I got an 'ESP malfunction, visit workshop' message on the dash, so I put it on a flatbed and off it went to my indy. He called the next morning to ask why I had the car delivered because it started first turn and he could not find any codes on his MB diagnostics. He kept it for a week and it ran perfectly. I bought a spare CPS just in case, but the problem has never resurfaced. I would strongly advise against the 'ECU fried theory' because A: they are ridiculously expensive and B: I have never heard on one going before. Speak to Shardul - he is awesome at this kind of stuff. Hope you come right.
mAMG's Avatar
SL55 2003
Check the fuel relay. Good luck.
Old Aug 12, 2014 | 04:33 PM
E55Freak's Avatar
2005 E55 silver
i'm pretty sure it isn't the fuel relay since he is getting pressure to the rail...
