stock supercharger snout bore ?
2004 W211 E55K, GL550
want to do a throttle body upgrade and wanted to see. If anybody has had their stock s/c snout bored from74mm to 82mm and roughly how much do you think orknow it will cost to get bored? also if there's any Chicago guys that could refer me to a place I would appreciate it. I had one place quotes me a price of 250 is that about right or does that sound high?
'06 E55
I'm having my 82 turned into a 90+ right now. It's at a welder's shop and he is building up some extra material around the inlet. He said probably around $90 to add the material. Then, I'm taking it to another shop to do the boring and tapping threads for the bigger TB. He said probably 4 hours to do this, but is charging me only $30 per hour since he's a car guy, and he's going to let me help.
So, $250 sounds about right for the boring, if there's enough material. Keep in mind that the current and "new" circle may not have the same center point. Put the new TB on the snout so the bolt holes are lined up and then take a look inside to see where the material needs to be removed.
no problem to weld a adaptor plate to the stock 74 inlet & bore to 82mm. Speedriven had a machined adaptor plate he sells ready to weld on.
How much will this cost you after the cost of the throttle body? Just curious cause it would be much easier to get the 82mm tb kit from Shardul which comes with a port matched snout.
[QUOTE=scoto;6133931]no problem to weld a adaptor plate to the stock 74 inlet & bore to 82mm. Speedriven had a machined adaptor plate he sells ready to weld on.[/QUOTE
Yeah i called them today and they are all out but said they will have some made by next week. Also with the adapter plate I wont need to have any threads tapped cause the ones they have tapped in there would mount right up correct?
Havent been on here for a while didnt know shardul had a kit what does his run? But all said and done I should be under 650 with snout bore,2nd hand t.b ypipe from dealer and and other addition pieces I need.
I can not speak for current pricing but would be worth contacting him to see what he can offer. I can say that my 82mm is through him which looks great and has performed wonderfully from day one.
