Standalone and functionality.
I do a lot of CAN work and have a pretty firm grasp of the messages that make the car work. So basically I wanted to know what things would be acceptable to loose and what would not. The ecu would not necessarily be what I would work on but the interface with the rest of the car. Although it would be easiest to build around a specific ecu. The ecu would have to be a drive by wire ecu of course so that already puts that cost in the higher end stuff that would have a fairly decent CAN data stream to work with.
To be realistic I think the interface would probably be in the 1200-1500 at least. So that would be on top of the ecu. We would be taking CAN messages and translating them back and forth and also CAN to analog and vice versa. I think I could get most of the car functioning fairly easily but do not want to waste the time for the usual yeah we want it but at megasquirt prices.
I would simply start there, if we can get a standalone ECU to mirror the information the EIS needs to verify then we can get the car started. From there it's a piece of cake as the ENG and BODY are 2 different CAN systems and they only talk to each other on 1-2 modules.
But if only two or three people would even do it, then it simply is not worth the trouble.
At this point all we need is an ECU and TCU controller.
https://mbworld.org/forums/w211-amg/...ontroller.html
BOOM solved. Again the only issue is getting the ECU to transmit the internal checks & data to we need. The rest of the systems are separate.
http://bayhas.com/mercedes/w211/cont...networking.htm
http://www.mercedestechstore.com/pdf...2009-03-02.pdf
it seems that past low 11's your at the point of diminishing returns. I'm happy with that, it's my dd. A 211 wouldn't be my first pick for a race car. Too heavy, big and $$$ to mod. I thought my c5 was expensive to mod with the "corvette tax"
That being said, a stand alone, or a good piggy back would be very nice. As long as all the factory components still work and function like oem. Just not sure how that's possible.
Reread what you said; so if you remove EIS/LOCK you then run into major issues right? Other systems are dependent on one or two messages that the EIS sends right?
Did you create/design that TCU controller?
You cannot simply remove the factory ecu and stick a standalone in and have everything work if that is what you are saying. But you can still turn the key and turn the car on. If you want proof just go unplug your ecu and turn the key on. If you were to have a CAN adapter hooked up to the CAN bus you would see the start message if you knew what to look for. Like I said I have an w211 EIS, key, steering lock and ecu on my desk that I have been working with. I can have the ecu not connected and just have the EIS and steering lock wired and powered up and it will release the steering lock and turn to the start position. THey are all married to each other so you cannot use one in another car unless it was made a virgin and then married to that car. Ecu that is. You cannot also just send the start message to the ecu without the DAS release from the EIS.
I am not saying it will be really easy to get all the CAN messaging correct but it is certainly doable. Some stuff is more complicated than others though. That is why I asked what would be acceptable to loose. Like maybe certain traction functions or cruise control depending on the ecu being used.
If we get a standalone inside the car, we wouldn't run into issues with functionality of systems inside the car (windows, locks, radio) right? This is because the CAN systems are separated?
What I mean by other systems is that engine, traction, transmission, are very interrelated. If you remove one you must get the data that is sent to the others replaced. And you are also receiving data from those control units. In some cases they will expect a certain response or they will set a fault code if the result is not seen. So if you have a request for less torque from traction control it may expect the torque output message to be reduced. And if not it will set a fault. You never know how much logic is in there until you start removing things and see. The fewer messages and functions that need to be dealt with the easier this is.
For instance the tcu is fairly simple to replace. In the Dodge cars I do not even get a check engine light with a few basic messages. Merecedes is actually easier to do and will operate without the tcu and no CAN messages but getting rid of the check engine light is much more complicated. There is a checksum in the CAN message that the ecu is looking for. Not hard but different.
Once I complete the task ill offer kits for wiring and write ups on terminal pinouts.
