W211 E55 Check Engine Light Help
Old Sep 6, 2014 | 04:52 PM
Syntaxerror's Avatar
E55 AMG
I was putting on my new CF lip on my E55 today and I had to jack it up. I lifted up the drivers side first and then the other side. When I was done, I drove around and the check engine light came on. The throttle response is great and everything works as it should. No malfunctions show up on the dash and I'm at a stump. I'm going to check the gas cap because right before I installed my lip, I filled it up.
Any suggestions on what it might be?
Old Sep 6, 2014 | 04:54 PM
MomentumE55's Avatar
2004 E55
Not sure about check engine light but how about a picture of the lip you installed?
Old Sep 6, 2014 | 04:58 PM
jcjmw's Avatar
2005 E55 Wagon
You should pull the code. You can go to pepboys or the like and buy an OBD II scanner and pull the code. Once you get the code that is causing the cel, then you will better know what the problem is / needed solution.
Old Sep 6, 2014 | 05:40 PM
E55 AMG
I wish it was that easy. I'm in CA, so I can't do that.
Old Sep 6, 2014 | 06:23 PM
E55 AMG
Old Sep 6, 2014 | 06:39 PM
jcjmw's Avatar
2005 E55 Wagon
There are no auto parts stores in CA?
Old Sep 6, 2014 | 06:56 PM
Bramage's Avatar
F-250
Nope, they closed all pep boys, O'rielys, Kragen, Autozone. They are all now Starbucks... Its rough But easy to get a latte'
OP, swing by Benz Works (HB) He can check it for you, or most auto parts stores can either do it, rent the tool, or buy one. You need one with this car
Old Sep 6, 2014 | 07:21 PM
2004 E55
Spoiler looks super clean, thanks for pic
Old Sep 6, 2014 | 09:58 PM
O-55's Avatar
2005 E55, 2009 VW GLI
It may be an emissions error. P0456 comes to mind. Good luck!
Old Sep 6, 2014 | 10:58 PM
E55 AMG
Thanks!
And I went to Autozone today and was told that they don't check codes anymore. I guess the same thing applies to all major chains as well.
I went on a ride tonight and before I took off, I removed the gas cap, checked it, and sealed it tight. After a couple of minutes of driving, the CEL went off. Hopefully it stays that way.
