ride height error message displays sometimes
Sometimes when I start my car, I'll get the ride height workshop message. But if I turn off the car and back on, it goes away. It shows up every once in a while, anyone know what's the issue?
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
The issue? Take those warnings seriously, an AirMatic failure pretty much disables the car, get it checked out or risk being stranded.
Since the Airmatic has so many components, it's hard to figure out the problem without the proper diagnosis. I have had that error message come up many times, and it has been a different issue each time.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you usually get this message when the pump exceeds the threshold time set to fill up the central reservoir. Once the central reservoir is filled the error will go away.
this is a sign of a failing airmatic pump
