"Top End" refresh
The list I think that would be low hanging fruit is:
1) Injectors
2) Vac lines (which ones, doesn't seem like TOO many)
3) Intake seals
4) Cam cover gaskets
5) spark plugs
6) Wires
7) **Coils** - kinda pricey to do all
8) ?
Any gotcha's? Any BTDT's? WYIAT's?
I know not many here are off of the stealer tit, but I have noticed some are - some major work is being done in the garage's of the enthusiast community.
Specifically - the injectors - If I am going into change them, I would like to do some larger ones for more headroom on petrol at first (e85 later) and with them being new, I'd kill two birds with one wrench.
Action Item: Do I need a tune for the larger 550 or even larger units?
2. if it aint broke dont fix it
3. intake seals?
4. cam cover gaskets?
5. def do this (night and day difference for me at 105k)
6. def do this (night and day difference for me at 105k)
7. def do this (night and day difference for me at 105k)
8. K&N filter
Also are you looking to mod the car? Or just do a tune up on it?
New injectors are just sort of required at 85k. Bigger ones would help me lay the groundwork for later mods. Seems like a win win. Unless it gets too complicated with the tune.
Vac lines are 85k and 8 years old. New parts are better than old parts, right?
Air Filter. Hmmm.
3. intake seals?
8. K&N filter
Thank you
). I bought an aftermarket kit for about $180 wire kit, and I think the dealer wants $240+ for them. Maybe with the coil packs you might be able to get away with not replacing, but I felt a HUGE difference once I changed my old plugs, coils, and wires (I also installed K&N filters when I did my initial oil change). Also I think toadster has a link to aftermarket coils + plugs for like $180!
82k. Yes - that is related of course. I have been putting that off because of wanting a better solution. Some other sender, pump and filter solution was my wish.
Great minds think alike.
-Your injectors are not a "replace at 85k" item, not even close. Chances are the car had premium fuel run it's entire life, but have the injectors flowed and cleaned if you're concerned. If you're planning on extensive mods in the future, the 550cc ones might not be a bad idea.
-Definitely replace the plugs and wires.
-Not a bad idea to replace the valve stem seals.
-The Weistec supercharger is more like $8k +/- plus you can get $2k +/- back from selling your old parts. If you're on a tight budget I strongly suggest you not modify this car too extensively!
-Best of luck with it whatever way you choose to go!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
