180,000-Injectors?
Waiting for someone with an 06 E55/CLS55 or SLR to get the numbers/pics of their injectors. At this point unless something new comes up, 03-06 injectors are the same imo. There's an injector testing/cleaning company about 30 min away from my house, if anyone's got those 'blue' injectors we can bench test the flow rate vs the 'black' ones and put this to rest.
If you want a slightly larger injector w/o the need of rescaling, these should be fine....if you step up to the aftermarket options, you'll need a complete tune.
I have posted the part number and picture in another thread...They are different and were placed on all late model 06's...the larger injectors were designed for the SLR but used across all of the K motors in 06.
2006 E55 AMG Injectors -
2006 SLR McLaren Injectors -
This is from my BOSCH source!
Just saw your post, and those guys are closed for the day but I will definitely reach out to them tomorrow morning. Their prices listed online: Clean and Flow ($20 per injector) or Flow Test Only ($9.00 per injector). PM me the last 8 digits of your VIN.
06 CLS55 AMG BOSCH #s -
09 G55 AMG BOSCH #s -
03-09 55K - Q-stat (at operating pressure {380kPa}) (g/min) or MAX flow ^ rate is 349 gallons/min = 484.7 cc/min
03-09 SLR - Q-stat (at operating pressure {380kPa}) (g/min) or MAX flow ^ rate is 380 gallons/min = 527.8 cc/min
It could be the other source of information is wrong as everything I can find on these injectors say/show that they are the same. Idk if someone got duped into purchasing these 'light blue slr' injectors but from everything I've posted/read call BS. Still I do like a nice experiement to set facts straight and will def be sending in my 'black' injectors to get flow rated and if viper04 sends his we could test them both. I also just spoke with another company, (my guys only do diesel injectors) and the prices to test are the same above.
