Heat Exchanger Install - Eurocharged
Pretty straight forward install but looking for any additional tips on this H/E vs the rest. Drill the mounting tab for bolt along with bumper support. Hangs from the front...
Question is: do you guys just walk the bolt into the support till snug ? I'd rather get a nut onto the bolt from the back side though. Support is double sided I believe (hollow middle)
![Heat Exchanger Install - Eurocharged-imagejpg1_zps4ee5ff60.jpg](https://mbworld.org/forums/attachments/w211-amg/396853d1542332699t-heat-exchanger-install-eurocharged-imagejpg1_zps4ee5ff60.jpg)
![Heat Exchanger Install - Eurocharged-imagejpg1_zps1ecc85ad.jpg](https://mbworld.org/forums/attachments/w211-amg/396854d1542332699t-heat-exchanger-install-eurocharged-imagejpg1_zps1ecc85ad.jpg)
E55 bumper guys - trimming on the lower H/E corner for the Eurocharged unit ? Also read some posts about not being able to reuse some mounting bolts
Pic I looked up for general reference:
![Heat Exchanger Install - Eurocharged-100_2016.jpg](https://mbworld.org/forums/attachments/w211-amg/396855d1542332705t-heat-exchanger-install-eurocharged-100_2016.jpg)
Noticed the trimmed edges around the exchanger
![Heat Exchanger Install - Eurocharged-100_2021.jpg](https://mbworld.org/forums/attachments/w211-amg/396856d1542332705t-heat-exchanger-install-eurocharged-100_2021.jpg)
As you said, pretty straight forward. I didn't trim anything, just mounted it. Ask a friend to help you as it makes removing and reinstalling the bumper cover much easier.
Got it mounted today. Solo job on this install as with almost all my projects..
For future searching, hope these can help.
Line up the the H/E to sit in the middle.
I used a jack and some wood stacks to hold it in place so I could drill a pilot hole thru the mounting tab and leave a mark onto the bumper support. Do a pilot hole onto the crash bar next. Then step up to what size works for you. I used 3/8's bolts to secure mine.
![Heat Exchanger Install - Eurocharged-imagejpg1_zps2c842619.jpg](https://mbworld.org/forums/attachments/w211-amg/396791d1542332689t-heat-exchanger-install-eurocharged-imagejpg1_zps2c842619.jpg)
![Heat Exchanger Install - Eurocharged-imagejpg1_zpsa79fbb5f.jpg](https://mbworld.org/forums/attachments/w211-amg/396792d1542332689t-heat-exchanger-install-eurocharged-imagejpg1_zpsa79fbb5f.jpg)
![Heat Exchanger Install - Eurocharged-imagejpg1_zps64cdde48.jpg](https://mbworld.org/forums/attachments/w211-amg/396793d1542332689t-heat-exchanger-install-eurocharged-imagejpg1_zps64cdde48.jpg)
Now in my original post I wasn't too thrilled about the thin walled crash bar (hollow inside) holding the bolt on 'snug' for the exchanger. I used a longer drill bit and went right thru to the other side so I can secure it with a nut![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I had bought some longer 3/8's bolts so I then cut them to my desired length and used a lock washer/nut as you see in the pic below
![Heat Exchanger Install - Eurocharged-imagejpg1_zps26db743b.jpg](https://mbworld.org/forums/attachments/w211-amg/396794d1542332689t-heat-exchanger-install-eurocharged-imagejpg1_zps26db743b.jpg)
I managed to get the lower cooler to sit exactly like stock & reuse the air diversion sheilds to it. Even the one all the way to the rear (under radiator/condenser). I would prefer these H/E's to have mounting tabs for it honestly. It does not touch or interfere with lower bumper or tray but it's in all how you set it up. H/E fits well too with no notching of the bumper to fit. I will fab up some mounting brackets on the 63 front bumper install next round.
The space between the Heat exchanger and the bar, you lose the 2 mounting bolts for the bumper b/c of the H/E mounting tabs being right in the way. I then trimmed the mounting holes off the rear of the bumper but I left some real estate so that still slides between the H/E and crash bar so it acts like a buffer and also seats the bumper still.
Hope this helps others.
