E55 jumping out of gear in manuell mode
E55 W211
I´ve got a big problem... my e55 w211 jumps out of gear in manuell mode.
The problem is only there while hard accerlation and the most time when its wet.
In mode S or C everything is fine.
The car had a oil change 1500km ago.
PLATINUM SPONSOR
Check the shifter cable/linkage that goes to the trans.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
If this is the case would it still show being in D or N. Mine did this the other day when I went WOT from 60mph. Felt the same as when my conductor plate was having problems but that was replaced under 10k miles ago.
