E55 Auxiliary Battery
http://www.ebay.com/itm/221541178292?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Mike T.
http://www.mercedestechstore.com/pdf...2011-29-02.pdf
Particularly slides 22 and 23.
Like Shadow5501 stated, this is a main battery issue, not the auxiliary battery.
Here's a link for that particular battery. There are tons of others on there. Also all the stores have them too. You just can't tell them what you're using it for because they'll claim they don't have the right battery. These batteries are used mostly in power sports applications. I actually ended up just grabbing a Magna Power from Sam's Club. You just need a 12v 12 ah battery with at least 170 cca. The Sam's battery had 200 cca.
The car still has the original batteries. I think i will just change both. Should i unhook the terminals first of the main to see if anything changes? Will i have to reset anythig if i do? Thanks
They ran a diagnostic and some codes came up unrelated to the aux battery. The aux battery was replaced in 2013 and main battery tested out fine. They still cannot find out the exact issue and won't know until tomorrow( weekend they are closed)... Any other reasons why I have the " low convenience options" light if both the batteries are fine??
thank you!
