S/C Pulley ?
2007 sl65 amg
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Sorry for crating a Thread! Can I drive my car with S/C installed but not ECU. I am waiting for Eurocharged to send me a ECU tune file back but my S/C is installed!
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
That's probably a bad idea. If you need to just take it short distant you could baby it over but you don't want to be driving it without a proper tune.
2007 sl65 amg
Installed the S/C pulley and Tune today. The car is a different animal now. So much more throttle response and low and tq. Just love it.
Tire wear on the other hand, not so much!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
I know you have already installed it but I'll add my 2cents for future modders.
Stock tune is **** poor rich. Adding a supercharger pulley (clutched) did not make my car run any leaner at high rpm (5000 and up). Around 2000 to 3500 rpm was much leaner at WOT but not dangerously so.
If anything getting a tune leaned out the upper rpm considerably moreso and slightly richened the low rpm.
There was no appreciable difference at part throttle, maybe tip in was leaner but that could be my imagination
PLATINUM SPONSOR
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
