What weight gear oil for LSD equipped rear diffs?
Old Dec 10, 2014 | 05:59 AM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
SO I recently pulled the trigger on a Quaife and am getting ready to install it, but am curious as to what weight fluid seems to work best for them.
Stock I believe is 75w85. I've had a few different answers as to what's ok to run but am curious as to what the masses are using. I'm either using AMSOIL or Redline. I've been weighing 75w140. Is that correct or am I looking at the wrong weight?
Old Dec 10, 2014 | 02:18 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Most use Mobil 1 stock weight but best to ask Quaife what they use for the LSD and style racing you will do.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 11, 2014 | 05:01 AM
WANTED!!'s Avatar
Not really a fan of Mobil 1 or Royal Purple, but I'll keep that in mind.
Old Dec 11, 2014 | 06:37 AM
kponti's Avatar
E63
Being that it's gear operated lsd system, stock weight good quality will be just fine I believe.
Old Dec 11, 2014 | 07:09 AM
WANTED!!'s Avatar
So according to their site, which I had confirmed through email from them, they recommend a hypoid 90 or 75w90. Amsoil Severe Gear it is then.
Old Dec 11, 2014 | 08:34 AM
kponti's Avatar
E63
I like Amsoil
Old Dec 11, 2014 | 11:22 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Originally Posted by kponti
I like Amsoil
You have too much money then
