ac secret menu reset
so i went into the hidden ac menu by holding the ac/0 buttons. out of curiosity is pressed the passenger temp buttons and now the info numbers no longer move for the specific item. is there a way to reset this menu?
Found out that if you mess with the settings the values no longer read live. To reset all you have to do is turn off the key while still in the hidden menu. Next time you go back to the menu all the settings will be back to normal.
