M113K motor worth more than most E55s on this board!
http://www.ebay.com/itm/850-HP-Built-AMG-motor-for-the-55-Series-Mercedes-Benz-/281329354280?pt=Motors_Car_Truck_Parts_Accessories&hash=item4180894628
Eurocharged Performance is proud to offer our world famous 850 HP Built AMG motor for the 55 Series Mercedes-Benz!!
5.7L DARTON SLEEVED 55 AMG BLOCK
Darton MID Sleeves
Custom Eurocharged Mahle SLR Pistons
Crankshaft Modification
Rod Modification
Ported / Polished Race Heads
Oversized Intake Valves
Custom Valve Springs
ARP Head Studs
ARP Rod Bolts
New Bearings, Bolts, Gaskets, Valve Springs, Valves
Weistec 3.0L Twin Screw Supercharger
1000 HP Liquid to Air Intercooler
650cc Fuel Injectors
Larger Throttle Body
High Flow, Cast Aluminum, T6 Hardened Lower Manifold, Elbow, and Throttle Body Inlet
Valve springs are set to help prevent valve float
Eurocharged Custom Dyno and Track Tune
850HP on Race Gas / 775HP on 93 Octane / 98 RON
50 LB weight reduction!!
NO CORE REQUIRED! YOU KEEP YOUR CURRENT MOTOR!!
Whats the SC kit? 12k? Motor is stock crank and rods (Says "Modification"), massaged heads (3k maybe) Block is sleeved (should be 3k or so).... Machining, assembly, little "this and thats"
I would sell my block just to get out of the car if someone is looking (Darton sleeves, Carrillo rods, Weistec high compression pistons, ARP head studs, Weistec SC, 90mm TB, ported heads, PTE cams, etc etc)
The thing you have to consider is that these parts take forever to get. Not like a crate LS motor where you just click and it's at your house by the end of the week. When someone tells you it will take X amount of time. Figure they should actually be done in 3-4X amount of time
'So comparing to this, this is a great deal! And like said the SC kit alone is over 10k..
