Has anyone (permanently) mounted a fuel pressure gauge?
Old Feb 7, 2015 | 09:02 PM
uraberg's Avatar
2006 E55 AMG
I'm considering mounting a digital fuel pressure gauge, just to see what's happening under driving conditions.
I'd like to just find a sensor that threads right onto the valve at the fuel rail, but I've not found anything like that. Does anyone know of this particular setup?
Old Feb 28, 2015 | 12:03 PM
uraberg's Avatar
2006 E55 AMG
I'll just answer my own question.
Summit sells an adapter that is -4AN on one side, and 1/8 NPT on the other.
http://www.summitracing.com/parts/CEI-107133
This allows you to thread a pretty standard fuel pressure sensor on. You feed it 5V, and output can go straight to a logging solution, or even just a multimeter.
Oh yes, remove the valve core.
Attached Thumbnails Has anyone (permanently) mounted a fuel pressure gauge?-img_20150228_113652240.jpg
Old Sep 6, 2017 | 02:18 PM
tw2's Avatar
tw2
Thanks for posting this. I was wondering what sort of adapter is required. You obviously have an electronic sensor connected, any issues with leaving it hooked up permanently?
Old Sep 7, 2017 | 12:12 AM
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
I guess adapter is as he posted. The sensor will send the signal to your gauge most guys will have the zeitronix setup and of course it's permanently mounted. No issues with that at all.
Old Sep 7, 2017 | 01:25 AM
tw2's Avatar
tw2
I was more concerned with a small chunk of metal hanging off the rail and vibrating. That sender looks a lot more lightweight than older ones I have seen.
